Old 29-Dec-2018, 10:19 PM   #4
Originally Posted by xboxman
Hi i have another questions and still can't post
was wondering if i had 2 identical antennas hooked parallel would my gain be a bit better ?
You can combine two identical antennas aimed in the same direction with equal length coax lines and a splitter in reverse to give you up to 2.5 dB additional gain, but there is no guarantee that it will help you at your location. Usually, your time is better spent in finding the best location for the antenna you already have.
also 36 feet above ground level i lost the bounce signals
so seems i get the bounce signals best at around 20 some feet above ground level
thanks
That makes perfect sense. You have to put your antenna in the spot that has the strongest reflection.
