Old 20-Dec-2018, 9:12 PM   #13
meazz12
You could try the 4V or 4Max. Or maybe even the 2V or 2Max. But those Clearstreams only have a single dipole for VHF so you might or might not pull in up WXIA NBC on RF-10. I think both are available in the big-box-stores, so would be easy enough to try and return if don't work for you. The 7694 is smaller than the 7698 and will probably work for everything if you are reasonably clear of trees and other obstructions.
Ok, the Winegard Platinum Series HD7694P is smaller and reasonably priced.
I already have a Antennas Direct CPA-19 preamp on hand. can I use that? Or just get the ChannelMaster 3414?
meazz12 is offline   Reply With Quote
