Old 20-Dec-2018, 5:11 PM   #12
jrgagne99
You could try the 4V or 4Max. Or maybe even the 2V or 2Max. But those Clearstreams only have a single dipole for VHF so you might or might not pull in up WXIA NBC on RF-10. I think both are available in the big-box-stores, so would be easy enough to try and return if don't work for you. The 7694 is smaller than the 7698 and will probably work for everything if you are reasonably clear of trees and other obstructions.
