Old 13-Dec-2018, 1:43 PM   #5
Tower Guy
Is there a reason he should go with a distribution amp instead of just a mast-mounted pre-amp.......? Maybe his signals are strong enough he doesn't need the amplification to be at the mast.
A preamp at the antenna would offer a few dB improvement in signal, but as you noted, as long as the antenna is not blocked by thick trees, or a nearby building, the signals are strong enough that it won’t matter.
