Old 6-Feb-2011, 11:55 PM   #3
jillnadine
Further how-to on the cables
That is EXACTLY what I have -- the single combined cable rather than the split-out tri-color one (THANK YOU for including those links w/photos! VERY helpful to someone who doesn't know the terminology!) And you are most certainly correct on the model of VCR, it's just my poor eyesight
Right now I have the VCR connected to the Video/Audio in ports on the front of the TV for playback with one of the split-out tri-color cables, and there is only one slot on the back of the VCR that will accept that type of cable (labeled AUDIO & VIDEO In & Out); the single combined cable is currently connected to the converter box via the ANT IN port on the back of the VCR. The only other port on the back of the VCR is the single-line-cable RR OUT port, which is still connected to the back of the TV but probably doesn't need to be since I don't have cable anymore (I really don't know). There are VIDEO and AUDIO ports I could plug a split-out tri-color cable into on the front of the VCR. After all that, here is the QUESTION: Do I just leave all those other cables in place once I do that, or remove the single combined black cable completely?
Thank you, MUCH appreciated!!
jillnadine is offline   Reply With Quote
