Old 28-Nov-2018, 3:55 PM   #2
jrgagne99
First thing I would try is removing the amplifier and connect a short lead of coax directly to a TV. If your garden-variety RV antenna is picking up all those stations, the GE yagi should do at least as well-- if it is working properly. If you don't get anything after removing the pre-amp, I would suspect bad connections at the antenna balun or bad coax.
