Old 10-Nov-2018, 1:31 PM   #8
gossamer
If I may, while knowing the difference between Azimuth and true
is important, aiming an antenna for the best signals overall is
really what matters. You may find that a few degrees either way
may provide a better signal. Also, the tilt of the antenna can also
contribute to improving the reception. Pointing the small end upwards
slightly can really make a difference!
The problem I have is that the antenna is on a 10' pole - I can really only visually adjust it based on the compass settings from the app on my phone.
Is there a better way to be more precise?
Also, while the majority of the channels are southeast (169 or so), there are some that are a completely different direction. I assume it's just a matter of picking the majority of the channels that I want and sacrificing the rest?
Thanks guys!
gossamer is offline   Reply With Quote
