Old 6-Feb-2011, 11:50 PM   #20
http://www.antennasdirect.com/store/...on_filter.html and http://www.summitsource.com/winegard...00-p-5346.html
Both are quality 'consumer' grade filters. Both would seriously impact channel 6 if it were a digital station. A Google search indicates that KBKF-LP is an analog station transmitting only audio, you may be able to receive the audio even after some attenuation through the consumer grade FM trap. If KBKF-LP is on your list of 'must have' signals and you can't receive it using the consumer grade FM trap, you may need to shop at Tin Lee for a commercial grade filter.
The cost of the consumer grade choices would make me try them first.
