Old 4-Nov-2018, 10:47 AM   #10
ZippyTheChicken
Hey Rabbit
heh i can tell you one thing don't do
use a CM7777 injector to power a 7777 and a RCA TVPramp1
Burnt out my RCA doing that
But I run two 7777s off my one injector about a 50 foot run and through a power passing splitter that combines both my antennas
and then I snapped the connector off my 7777 when I attached some coax heh
I just resoldered that with a new connector yesterday and tested it last night.. works. Got lucky
haven't measured the power at the amps/antennas .. probably should .. but its working for now
hope all the regulars are doing well here.. i get here once in a while but I am mostly on Reddit .. hope the site is doing well . and the owner... never really heard that story..
anyway just passing by heh
I thought there was something wrong with my signal level meter, so I substituted a CM7777HD at low gain:
Gain: 17 dB; right where it should be.
My meter is OK, the RCA preamp isn't OK.
I can't recommend the RCA TVPRAMP1 preamp.
ZippyTheChicken is offline   Reply With Quote
