Thanks for the help. One, non-grounding, question.
As mentioned earlier, I'm combining the two antennas (DB4e and MCM-2476). I've always had an RCA preamp. I'm sure it will not hold up as well outside as say the Channel Master 7777 would, but I'm starting with that and the RCA has a separate input for VHF and UHF.
I assume this means I will have no need for a splitter/combiner. But, I also know that the RCA preamp can be fickle. Do you know if the RCA preamp will combine my two antennas using the standard inputs without issue or should I prepare for something else before I start this process?
