Old 29-Oct-2018, 4:07 PM   #4
JoeAZ
Defiance, OH is between Ft.Wayne and Toledo. The stations in Ft. Wayne are
all UHF. The stations in Toledo are both UHF and VHF. Ft. Wayne is actually
a bit closer to Defiance. In most cases, the only way to change between the
Ft. Wayne antenna and the Toledo antenna would be an A/B switch or a separate
tuner connected to the television HDMI port. If the setup had a UHF only antenna
for Ft. Wayne and a VHF only antenna for Toledo, then a UHF/VHF signal joiner
could be used. Hope this helps..........
