Mounting my db8
Approximately 8+ft above my roof is my very old Radio Shack antenna and a very old RS rotator.(tripod, riser mast,rotator and mast) I just bought an antennas direct DB8 and the mast mounted above the rotator is not long enough for mounting the DB8.
I would like to get the DB8 up higher if possible and wondering just how much higher would be a safe bet. i will replace the upper mast with a longer one and move up in diameter a bit too. How much is too much...
