Old 23-Oct-2018, 3:04 AM   #9
gossamer
For the mast you don't need the coupler like is used on coax, just the split bolt to clamp it to the ground wire going to the rod.
Mount it below all that other stuff, just wire to wire.
Can I use one of the existing split bolt, or are you suggesting I should splice the wire again for my purpose?
gossamer is offline   Reply With Quote
