Old 19-Oct-2018, 11:45 PM   #5
Your splitters only need to cover up to 700 MHz, the current limit of broadcast television signals. There is no need to replace them just for the frequency rating you indicated.
If you have the PS1403 installed but no actual amplifier installed, you need to remove the PS1403. The DB4e's balun isn't affected by having a "hot" coax, but other antennas will be,
