Grounding rod requirements
Hi, I've installed an antenna on my roof and was grounding it using the same terminal as the cable broadband connection. Cable guy said he didn't like that and cut my ground wire.
Does it somehow affect signal quality, put us in danger in some way, or was the guy just being a jerk?
In any case, I've also read that some places are only allowed one grounding rod per dwelling, so was hoping to get some expert advice on how I should proceed.
What's the best approach to grounding an antenna in northern NJ?
