Thread: Which antenna?
Old 16-Oct-2018, 7:56 PM   #7
Homer6
Homer6's Avatar
Both antenna have 300 ohm connectors which are connected to 75 ohm adapters, with RG 6 coax running from the adapters to the preamp. I believe the preamp is factory set with the FM trap set, so I left it that way. The RG 6 coax running down the tower, to the attic, is connected to the power/output connector on the preamp. Hope this helps.
Homer6 is offline   Reply With Quote
