Thread: Antenna advice
Old 5-Oct-2018, 2:31 PM   #13
jrgagne99
You're supposed to ground both the mast and the coax shield. Both are accomplished with the bronze-colored grounding block that Rabbit posted. The grounding wire from the mast and a jumper to the copper stake go under the set screw.
