Thread: Antenna advice
Old 4-Oct-2018, 4:54 PM   #10
Smityyone
I probably should have been more clear with my question. Where is the best place along the RG6 run that the grounding block should be placed? Anywhere between the antenna and the first junction? Before or after the pre-amp? I assume definitely before the splitter. Also, to use the electrical system and/or a grounding rod, the grounding wire run would need to be 5 times farther away than using the nearby plumbing system, which is already grounded and has several grounding attachments already in place.
Smityyone is offline   Reply With Quote
