Thread: Antenna advice
Old 3-Oct-2018, 4:41 PM   #5
jrgagne99
Let's keep this all in the same thread. Here is the post from the parallel thread you just opened:
Originally Posted by Smityyone View Post
I'll likely order a BD4e antenna based on recommendations from here. I know getting the antenna as high as possible will give me the best results, but I'd prefer not to install it on my roof peak, instead wanting to use a J-mount (or https://www.youtube.com/watch?v=Uas1t68hW8E) attached to my fascia. My roof has a very shallow pitch, so I'd only be losing about 5 or 6 feet in height. What is the tallest mast I can attach to these mounts, what diameter pole, and where to buy? Although I would prefer not to, I could add two supporting braces if that would allow for an even taller mast. Where would I get these supporting braces if needed?
Depending on windiness, I wouldn't go much over 5 feet on an J-mount with a DB4e. Lots of places sell these as kits with the 1.5" or 2" mast and all necessary hardware. Solid Signal comes to mind, Antennas Direct sell them as well.
