Old 3-Oct-2018, 12:22 AM   #13
corvairbob
To run Rg6 above ground frume point a to point b use STEAL CABLE ??
i could but that run is like 50 ft and i don't want wires in the air. i can run them to the front garage as i have a 2" pvc pipe buried but to get that i then have over 100' i tried that and it really did not help. if you can see my garage you can see a tripod on that roof and i did have an antenna there for a bit but because it is only 20' above the ground my house was also in the way. so i gave that up.
corvairbob is offline   Reply With Quote
