Old 2-Oct-2018, 2:16 PM   #10
corvairbob
Originally Posted by Statmanmi View Post
Hello fellow West Michigander Bob,
I've found that I can now post into the TVFool forums. I don't think I ever received an e-mail that my userID on the TVFool site had been approved after I signed up about a year ago, but I'm glad I tried a post last month.
I live 44 miles almost straight east from you, but have also helped a friend with his antenna in Ravenna. It was a year ago that I started really geeking out on getting OTA (over-the-air) TV antennas going, first for myself at my relatively-new location east of Cedar Springs and west of Greenville--then by helping a few others. If your curious later to read more about my particular antenna set-up, this avsforum post describes it: https://www.avsforum.com/forum/45-lo...l#post55665130
I've read through your thread here (from Sept. 2018), and also your year 2016 thread where Rabbit73 and others offered you some assistance.
Maybe some of my following thoughts and questions will help you, and no big deal if they don't.
I'm understanding that you're wanting to reliably receive channels 29.1,2,&3. Do you ever also receive 15.1,2,&3? The 29 channels are just duplicating the 15 ones, but from the closer tower to Muskegon and at a lower power. Thus, if you can get the 15.1,2,&3 to come in always, you wouldn't need the 29s. 15 and 29 are both station WXSP, with MyNetworkTV as the .1 subchannel.
In the 2016 thread, you included your address--and haven't removed it yet. Rabbit73 likely zoomed in on the Google view like I have, and he asked then if you have any of your antennas pointed into the large trees that seem to be shown at each end of your home.
Trees and their leaves don't play kind at all with TV signals. Especially when the leaves get wet and move around in wind. You mentioned that you lose the signal during rain, so that has me thinking that the trees are some of the situation you face.
the antenna on the north on my roof is not looking between the trees at the 29 tower. that tower is about 6 mile north and i can just about see it. for 29 and the 17 tower is
more towards wolf lake from me and that is thru the trees and i also never have issues. so 29 must just be a low power. channel. steve at tv8 told me they
updated the tower system this past june so it is working much better. i think they started low power until they started to get complaints and then upped the power.
Have you ever tried a single antenna from your garage roof or southern end of the house roof, pointed southeast? I suggest that location, as that might be your best shot at having the trees the furthest away from your antenna. Looks like you'd still have trees in other neighbors' yards, but it would avoid those on your own lot.
stateman. tried on garage roof but the cable was to long to run and i did not want to have the cable in the air no good way to support it
Trying a single antenna would eliminate the likely loss of signal occurring with your combiner use. Lots of us find how to point a single antenna and still get TV signals from all around. It's usually a matter of pointing at the weakest station and seeing if the others still come in enough for the TVs and devices to decode.
tried single antenna on the north and the south. i have now installed since 2016 the same antenna both on the north side on the roof pointing to the north northeast.
and one on the south pointing south east. and the uhf for 35.1,2,3,4,5
when i used the north antenna i got 17 29 13 when i used the south i got 13 35 54
so i need both to get 13 17 29 35 54 once in awhile 8 shows up. i know 15 is the same as 29
You had mentioned channel 49 in your 2016 thread. Realize that they've been having problems, and only recently noted with the FCC that they're back on the air at only one third of their usual low power:
bud owns 49 now 39 and has it running but now all the time and because it is running so low on power my antennas can't get it even in the fringe and they are 3
miles to the south
https://enterpriseefiling.fcc.gov/da...65b09ceb9e07df
If that link doesn't work, then use this one, and go to the bottom where there's a link shown as "WMKG REASON FOR STA":
https://enterpriseefiling.fcc.gov/da...ct-attachments
Do you ever get NBC at all (WOOD TV) on any TV? It could reach you from two places: That same tower 6 miles northeast from you like 29.1, but not making it through the trees all the time. Or, it might be more reliable to get it to come in from their main, full-power tower by Gun Lake (south of Grand Rapids), so southeast from you--through the best available gap in the close-by trees. Just like with trying for 15.1,2,&3 instead of the 29s.
now and then 8 comes in as 8 but they are also 29 and they are working to improve that north east tower. i'm not a first name basis with steve the engineer there
one thing i have pointing to the south east is a power xformer on the pole just about directly in my way. this past aug that xformer burn out and they replaced it and
the channels now are better. so that xformer must have been disturbing the signal.
You asked in 2016 how there could be 3 different sources of Fox 17 shown on the charts. That station has many different towers, more than either WOOD TV or WXSP. Yet their management chooses to have almost all their extra low-power towers map into TVs as 17.x--confusing, isn't it?
You also mentioned about having a preamp and distribution amplifier. If you do try just a single antenna again, I'd suggest first not having the preamp nor distribution amplifier in place. Just have the antenna's downlead coax go to a single TV. If you can get a picture coming through from most of your problem channels, then add the preamp in (what brand is it)? Note that it's not too common that people need both a preamp up on the mast, and a distribution amp further down the line--usually it's only one or the other.
did that as i have a tv in the garage on the wall next to my antenna system. and that one show the power with one button on the channel being use at the time and
i have tried all the things you talk about. the mast amp did not work at all i have a channel master preamp and all i use now is the power supply it works better that
the amp system why take a guess. and i have a distribution amp to have 4 tv's in use
I hope some of my thoughts help you Bob. I and others are interested in hearing back on any progress you make.
Cheers!
Statmanmi
statmanmi. thanks for this help here is the reply
the antenna on the north on my roof is not looking thru the trees at the tower. that tower is about 6 mile north and i can just about see it. for 29 and the 17 tower is
more towards wolf lake form me and that is thru the trees and i also never have issues. so 29 must just be a low power. channel. steve at tv8 told me they
miles to the south
Cheers!
corvairbob
corvairbob is offline   Reply With Quote
