Old 2-Oct-2018, 1:58 AM   #1
Srvguy
Recommendations for Better Signal Quality?
Current Report: http://www.tvfool.com/?option=com_wr...90383e43fec690
My current setup is a ClearStream 4 70-mile range antenna pointed in the range of 124 to 127 degrees. The antenna is mounted in the attic above the 2nd floor of my house (mounting outside is against subdivision covenant). The major networks (ABC, CBS, NBC, Fox) are a must have, the others are a nice to have. My setup for the last two years has been adequate, however, I do lose the signal 10% to 15% of the time. The weakest signal is the NBC (13.1).
I am checking to see if there might be a recommendation from those that have a lot more knowledge than me, for a slightly stronger antenna. Or, offer any advice based on general observation of the report, setup, and needs.
Thanks in advance for the help.
Srvguy is offline   Reply With Quote
