Old 27-Sep-2018, 12:16 AM   #5
BrooklinOTA
Actually, that's a mis-statement of how it works, it's pretty much an over-simplification.
A low-noise pre-amp's input noise figure would substitute for the combined insertion loss of the downlead and of the tuner (plus any other losses). Adding one, where appropriate, can extend the noise floor limit by a few dB, perhaps even as much as 6-10 dB for a typical tuner and preamplifier with 75' of RG6. IOW, very weak signals that would get lost in the cabling and tuner's input would have sufficient power to be above the tuner's noise floor and then may possibly be received (there are other factors..).
To do the actual calculations, you'd have to use what's usually called a "Cascaded Noise Figure" calculator or the equivalent to find the "System Noise Figure" when using (or not) a preamplifier.
Thank you, this helps to make more sense of it. In your opinion do you think it is worth me trying a preamp like the RCA model?
BrooklinOTA is offline   Reply With Quote
