Old 26-Sep-2018, 9:39 PM   #5
athiktos
It all depends...
Using separates allows you to customize to a greater degree while the combos are generally pretty limited as to what the relative antenna sections' performance might be.
Otherwise, when it comes to mounting, it's pretty much a comparison between a ranch home that sprawls or a two story of the same floor area that occupies half the land.
Thank you. My signal analysis is as follows:
http://www.tvfool.com/?option=com_wr...9038d5e534f23c
The DB4e works well for me inside, but I am going to mount both on an existing antenna tower. Would I be better off getting a 30-2476 or a 30-2475 in my location? The 30-2476 seems better because it has more gain, but I understand that more gain is not necessarily better.
athiktos is offline   Reply With Quote
