Old 26-Sep-2018, 3:12 PM   #1
BrooklinOTA
Looking for guidance around preamps
Hi Everyone,
I want to thank everyone for the amazing help I've received so far. Because of this forum, I'm getting some great college football, NFL and sports playoffs all for a bit of work and very little cash.
I have been puzzling over the situation with preamps for some time and I was hoping that someone could help me get some clarity. I understand that a preamp only helps with loss through the cable run and does nothing to benefit reception. Also, I have been discouraged from using a preamp because of the added noise that will be added.
All of that said, it appears to me that my system would benefit from the use of a preamp and here are my details:
Tv Fool report: http://www.tvfool.com/?option=com_wr...9038aaf236a07a
I have a run of 75 feet of RG6 coming from a DB8e going to a Channel Master distribution amp.
Now, when I look at calculations of loss over 75 feet of RG6 and then consider some of the channels I get that can be variable with reception, it seems the preamp would work.
Take NBC, real channel 33 for example. Channel 33 is broadcast at 587 MHZ and over a 75 foot run of RG6 I should be losing around 3.65 db.
So if that is the case, would it not make sense to introduce something like a TVPRAMP1R, that brings 2.6 db of loss into the system? Wouldn't I achieve one extra db of gain and it would help the channel be more stable when the signal is borderline in and out?
Thanks for the help!
BrooklinOTA is offline   Reply With Quote
