Old 23-Sep-2018, 12:49 AM   #32
Nascarken
Banned
Question Tilting the antenna fine tunel!!
Ordinarily, the antenna boom should be level, but at some locations reception is improved by tilting the front end up and even less often tilting the front end down.
Tilting the front end up sometimes helps if there is a hill in front of the antenna in the signal path close to your location.
Tilting the front end down is used when the ground in front of the antenna slopes down away from you. The antenna is mounted close to the earth and the antenna picks up the signal reflected from the slope.
Both the 30-2476 and the HDB91X have a tilt adjustment.
When fine tuning with the tilt find your far away tower's first ??
It will take too person and 2 cell phone one on the roof at the tilt feature
Why the other person is looking at the pictures and the SIGNAL strength master for best results ???
