Old 14-Sep-2018, 6:17 PM   #11
JoeAZ
Given your location, your best option would be to have two separate antennas. One pointed at Buffalo transmitters and the other towards Hamilton/Toronto.
Running two cables, one from each antenna to each television. Then you have to chose between an A/B switch for each television or a second tuner for each television. It's not a perfect solution but it frequently is the best one I can think of. Having lived In W.N.Y., I am very familiar with the area. Canadian broadcasters face huge challenges with all the U.S. programming from border cities, like Buffalo.
Revenue that could and should remain in Canada end up on the U.S. side of the border. For many years, Canadian cable companies would show U.S. programming from border cities and insert their own commercials in lieu of showing the actual
commercials broadcast. That is no longer the case. There is no easy or quick solution.
