Old 14-Sep-2018, 3:06 PM   #21
ravindran_eee
Thank you! It sounds like TVFool is probably not reliable when it comes to small height differences. It would make sense. And the problem with trees does not go away! May only make it worse with more cars going across. If playing around with height in the roof does not work, then I will try to bring it down and see if it works.
ravindran_eee is offline   Reply With Quote
