Old 14-Sep-2018, 12:16 AM   #6
Stereocraig
Originally Posted by wado66 View Post
The rolling lines are on all TV's they are using. One TV is probably 8 years old and one is about 3 years old.
With it happening on both TV's I think Tower Guy may be onto something with the ground loop.
Just for testing purposes, if it is a ground loop issue could I remove the antenna ground wire and see if it improves? Temporarily of course.
That is what I would do.
The ground wire, is mainly to bleed off static buildup, so I wouldn't lift it for very long.
Many pro audio amps, boards and effects processors actually have a ground lift switch, in case there are ground loop problems.
Those car stereo people also use line level isolation x-frmrs to minimize alternator whine that is aggravated by ground loops.
