Old 13-Sep-2018, 11:48 PM   #20
Originally Posted by niv
Took the PA off line. No Channel 12 on LG. Got 3 but no 5 on SDT but 3 very flakey through DA. No 3 or 5 straight from antenna so didn't bother to try through splitter. First time I've seen positive result from PA (or lack of PA showing negative results, either or :-) Also found a signal strength meter on the SDT. Will put the PA back on line tomorrow when I put the FM trap on. I've included a url to a pic of the antenna fins. Should they be horizontal or vertical or does it matter. Right now they're every which way. Hopefully the url works https://tinyurl.com/y8c8onww
These fins:
They look OK to me, but what are these extra wires? Are they connected to the coax downlead for the antenna?
