Old 13-Sep-2018, 8:13 PM   #2
jrgagne99
Originally Posted by BrooklinOTA View Post
2. I could try installing a preamp like the TVPRAMP1R and see if that helps amplify the Canadian channels better while I'm still having both elements pointed at 175 degrees magnetic. As I have a 75 foot coax run from the antenna to distro amp, I'm hoping this would help to overcome the loss from that length of cable.
I think the insertion loss going into the pre-amp would be about the same as the 75-foot coax loss, so likely would not help much.
I don't have any experience aiming the DB8e panels in different directions. It might be worth a try though. Other option is maybe to split the difference (aim between the two towers)? I've always had the most success when I bring a TV with me on the roof and figure things out in real time.
