Old 13-Sep-2018, 5:27 PM   #16
ravindran_eee
If you have trees it's up over them but if you can add 10ft to the ANTENNA and I suggest
In an channel master 7777AMP it will help pull them channels in
And if power lines are a problem IT'S the same thing up over them
Well good luck and be safe on the roof and look out for power lines when installing an ANTENNA.
Thank you! I will try to first add 5ft, which should make it 10 ft total. I might have to think of other ways of mounting or supporting the mast for additional 10 ft. I already have RCA preamp. Does this channel master provide better gain? I am not sure if my issue is in signal loss. The antenna itself is not picking up the channels. The antenna already seems to have good amount of gain.
Yes, I will be careful! There are no power lines over the roof.
ravindran_eee is offline   Reply With Quote
