Old 12-Sep-2018, 4:49 PM   #12
jrgagne99
Based on the 3D Google street view, it looks like the trees are tall, and less than 100 feet away, so additional height will likely be needed. Tilting the antenna up a few degrees might help. Frequency-specific hot-spots may exist on your roof, finding one that works for all frequencies of interest could be a challenge, but is possible. Only one way to find out....
Either that, or you could use the tree behind your neighbors house to the north. It looks to be much taller than the ones across the street. Maybe you could make a deal with him to put the antenna up in there then split the signal to both houses, you'd both get free TV. If you do that, put the pre-amp at the bottom of the tree for easy maintenance/replacement.
Quad shield and/or RG-11 is probably getting into the weeds. New RG-6 should be fine.
