Old 12-Sep-2018, 2:54 PM   #6
ravindran_eee
Despite the close proximity of your NYC stations, the signals are
not terribly strong. Most all your signals are reflected 1 edge or
2 edge signals. Because your location is blocked from receiving
Line of Sight signals, you are going to have to work a bit harder
to get reliable signals. As was mentioned previously, you need
to "walk the roof" to determine if there is a "sweet" spot where all
your stations come in properly. I think an amplifier/preamp might
be advisable in your situation as well as significantly increasing your
antenna height. Are there any trees or buildings directly East of
you??? They could be blocking what little signals reach your area.
Yes, there are trees right in front of my house. I don't know how to post images. I will figure out and post one later from google maps. Unfortunately, the towers are in the direction of those trees. They have grown a lot over years. Yes, I am using RCA preamp.
ravindran_eee is offline   Reply With Quote
