Old 11-Sep-2018, 9:39 PM   #2
jrgagne99
Welcome to the Forum Ravindran
It would seem you have the correct antenna based on the channels you're after and their relative strengths at your location, as reported by your TVFool report (which may be erroneous for your location, others will undoubtedly chime in on that). Are you sure you're aimed at 120degrees magnetic? Are there any trees, houses, or hills directly in the way? How long is the coax, and is it new and what type (RG-6 or RG-59)? Which pre-amp did you try (RCA TVPRAMP1Z), was the antenna coax plugged into the right port (UHF/VHF) and was it set to combined?
I think it is definitely worth fiddling with the antenna height and aim, and possibly trying other locations on you roof (callled "walking the roof") before moving up to an antenna with more gain (e.g. the 7698p or an 8-bay UHF and MCM-2476). Best to do this with one guy on the roof and one at the TV for live feedback. A few degrees left or right and foot or two up or down can make a big difference sometimes. You're def. doing the right thing by keeping it simple at first (one coax run, one TV).
