I have a Channel Plus Low Pass Filter LPF-380 Bandpass 0-380 MHz. Will that do anything for the FM trap?
No. That LPF will wipe out ALL of your UHF reception.
What would be a good DA for this situation?
Unless you have an extraordinary signal distribution system with lots of losses, avoid adding a DA and use a passive splitter instead with the mast-mounted PA.
I'd really start with the FM trap (or HLSJs) on the input of the Juice. For convenience, I'd also leave the PA at the base of the tower since I'm also getting too old to climb ladders unnecessarily. The insertion loss of that downlead prior to the amp would just be a necessary evil that could be later addressed when details are finally ironed out.
Note: I've turned off my private messaging again due to a persistent spammer.
