Both channel 29s are low power stations, so the range is much less than full power stations.
Multipath in digital can not be seen as ghosting, it simply prevents any reception.
Mileage ranges on antennas is simply advertising puffery. You can’t design or troubleshoot a problem based on best-case reception.
If you aim an antenna at either 29 WITHOUT another aimed at the second 29 and rescan, what happens?
