Well the box's on the Winegrud when I stagger stacked them the box I did not use?
Silly yes but when you use stuff like that can mess with what you RECEIVE ?
Like I have said before I use the channel master 7777,Amp with the fm,trap?
I have separated the uhf,frum the vhf. On the 8200u. So one amp.for uhf?
And one amp for vhf. With an A&b,switch. For the stagger stacked 8200u.
The hi&low,VHF,receive of,1500,miles away,and the uhf,receive of 90miles away!!
But with one 8200U,with the box's being used with the channel master -7777AMP,with
The fm trap!! Uhf,receive of 85miles,&the vhf,receive of 150miles of RECEIVE,,but I think
If you use 2 amp and do not use the box's the vhf receive will improve it you use an a&b.
Switch??? Yes Rabbit the hi vhf,ANTENNA by it SELF with a channel master 7777amp.
In southbrige MASS 01151 the antenna higth 45ft!!RECEIVE 25, so then I took one of
The HDB91 stacked 4ft and lost like 6 channels so then I used 2 amp one for vhf&one uhf.and yes I got my 6hi vhf channels back that I lost!! I think I needed the hole!!32:dbg
That the channel master amp puts out!!and HDB91 with a channel master amp hooked
To it buy it self!!!REVIVE of,90miles away!!
