Old 7-Sep-2018, 5:47 PM   #4
corvairbob
Bob has previous threads.
If he hasn't moved, I think this is good (or as good as TVFool can get it):
http://www.tvfool.com/?option=com_wr...9038ca707e6770
He started with combining "150-mile" antennas; now I think he is using an 8-bay with the panels aimed in different directions.
seems i don't get the notice i have a reply from this site for some reason i have it checked in the receive instant replies. don't have a clue why i'm not getting them.
thanks rabbit yes i have 2 antennas on each end ot my roof. the south one pointed east south east and the north one pointed north east.
if i use one antenna the south one i get 13.1 29.1 35.1 54.1 and all the subs they have
if i use the north antenna i get 13.1 17.1 29.1 and the subs i lose 35.1 and 54.1
i can go without 35.1 but like 54.3 or the 54.1 selection
looking at the pointer i see first from the north going to the east
17-42
9=32
13-46-29
then south east
36
15-48-48-44-10
29
7
24-11-19-8=20-45
25-33-5
these are all going clockwise from north to south and the channels are sequenced in the lines i see form what tvfool says i should be getting depending on distance
if it helps i can send pictures of the antennas and then you can id them and there directions and also i have the antennas going the a 2 into 1 combiner and then a pre amp and then a 4 way amplified splitter. the tv in the garage i use for the signal strengths shows this
north antenna 13.1 normal 17.1 good 29.1 normal no 351 or 54.1 and subs
south antenna 13.1 good 17.1 bad 29.1 good 35.1 good 54.1 good and subs
both antennas 13.1 great 17.1 great 29.1 great 35.1 great 54.1 great and subs
every channel comes in for the most part great but for channel 29.1 that one drops out all the time and he says humidity or sun or temp or fog or rain or wind. meanwhile all the rest are still perfect. i go in the garage and run them on that tv and they all still have great signal and 201 and subs are gone. but it show a strong carrier for that station. so i'm thinking they are not getting there signal to the transmitter.
does this help you at all. if you want pictures let me know. thanks bob p.
corvairbob is offline   Reply With Quote
