Old 6-Sep-2018, 1:31 PM   #29
Nascarken
Banned
This is not a good recommendation because you have no VHF-low stations. The large elements on the 8200U would be nothing more than wind-sails. Further, small RV antennas don't have the gain required for the signals you're after. At least not in the universe most of us live in.
but you see you are wrong becuse low band vhf is coming back??
And the way I see it & the Fcc.they suggest that when buying an outdoor tv antenna they say too buy a good hi and low combow uhf/vhf,hi&low outdoor!!
Tv antenna set-up like the Winegrud,8200u.with a 7777Amp!!Ha guy's
For the money one ANTENNA I have used the hi vhf,ANTENNA that Ribbit!!
Suggest I have 2of them stagger stacked with an A&B switching forum vhf/uhf.
And I received channel channel's in North Carolina and South Carolina&so on
With the hi&the low band Vhf.with low band vhf ? And with ATSC,03, with an
LG,TV with the Winegrud 8200U I have staggered stacked two of them &it is
Silly of RECEIVE ?? Better then the DB8,and yes!! Better than the HDB,uhf.only &the ANTENNAS DIRECT 91xg,that's also uhf, with the channel master -7777AMP!! And tech'S say 90miles for uhf.?with the antenna Direct 91&the HDB,91,at a 118Ft hi with the channel master 7777AMP!!90miles
Of RECEIVING in Massachusetts so know let's go back to hi&low band vhf!!!
That you can receive BROADCASTING station for at least 1500miles away??
Silly yes but with two wingard's,8200u,stagger stacked with the uhf/vh f
With an A&B switch and 2,channel master amp.on a 150Ft TOWER!!one
Ham,rotor!! It's the best of the best ANTENNA out there to day!!!
Silly me with my inverted V antenna set-up for my HF,rig!!! Lol,73!!Ribbit.
