Old 2-Sep-2018, 4:03 AM   #18
Originally Posted by realjet View Post
I'm sorry but I never put a antenna in. I don't see where to.
The reason you don't see where to put your antenna in your report is because there is no place to put it in. You can put your antenna height above ground, but not your actual antenna.
The report assumes that a simple dipole antenna is being used, and gives Noise Margin and signal power based on that. You can add your actual antenna gain to those numbers after you receive your report to see how much it will help.
