I appreciate the information. I haven't had a chance to look at the specs on the cm 4221 so I might answer my own question once I do. Do I need the yagi to get channel 11 because the 4221 doesn't go that low? I figured I wouldn't need to much to get decent signals due to the distance.
Would there be enough signal to be able to split the signal in two? I'd be looking at hooking up another tv for a two of two once I went this route with the antennas.
Another question I thought of while thinking about antennas, I'd be looking at hooking up an antenna to my home stereo and was wondering if I could use one of the suggested antennas or if I would need to buy a seperate FM antenna? I've read/heard that some tv antennas will work to bring in FM signals.
Again I appreciate the information.
