Old 30-Aug-2018, 7:55 PM   #5
jrgagne99
Your TV fool report was only resolved to block level, and so it is likely not accurate. Use the instructions in the sticky thread "A reliable method for generating a TV Fool Reception Report" to get a more precise report. Make sure to zoom all the way in and put the push-pin right on the RV site as seen in the satellite imagery. Enter the expected height of the antenna Above Ground Level- AGL (not the antenna type and pre-amp as prior post suggests). Also, please list the stations you wish to receive (by their call letters) so we can make a proper system recommendation.
