Old 6-Feb-2011, 4:29 AM   #8
Ok I have read your other posts so I know that you like to go after those hard to get signals. You know about the XG91 and you know how to find VHF long distance antennas. For maximum signal transfer and shielding from unwanted interference , RG-11 quad shield coax , grounded using a coax ground block connected to a good ground. And one of these ultra low noise amplifiers mounted close to the antenna. http://www.kitztech.com , http://www.researchcomms.com/hdtv.html , and you know that the antenna/antennas can not be connected to your main antenna. You will need a mulitpul antenna switcher like one of the remote control RF Switchers at http://www.tinlee.com , or you can switch antennas by connecting and disconnecting coax cables.
