Old 6-Feb-2011, 3:33 AM   #14
John Candle
Tv Antennas and Reception
Well Ok it's your choice but before you give the final no. Check this out , http://www.amazon.com/Parts-Express-.../dp/B0002KR74A and a clearstream2 UHF Tv antenna. The antenna can be mounted on a tripod antenna mount and set outside on patio/balcony and you can bring it inside any time you like. . Be nice to the flat antenna coax cable , do not slam doors or windows on it. All your receivable Tv channels are UHF Channels so the UHF out door antenna will work real fine.
