Old 7-Aug-2018, 2:32 PM   #76
JoeAZ
Greetings Dagwood,
I have a couple thoughts you may consider. I'd test an 8 bay bow tie antenna
or similar on your roof, completely independent of your current system. That
means trying new wire directly to the tv along with the new antenna. You will
need another person at the antenna or tv to complete the test. If reception improves,
you will have to look at your entire current system for issues. My opinion is that
the test will yield about the same results as you currently experience. In my head
I believe that all those trees are the real culprit........
