Hello there Rabbit 73, you can use a T connector and yes the ANTENNA's are combined into one I
Suggest you use a channel master 7777amp the ANTENNA's are separated 2,feet apart
And the feed line frum the ANTENNA to the T should be 2ft long.And out of the T should be as short as you can get it to the amp in put. Use RG,11, and this set up is for 2,HDB91,
That are only a UHF,outdoor tv antenna,good luck..And ha rabbit 73 hamer what else
Do you think you will receive with this antenna set-up tack a close look at the feed??
