Old 5-Aug-2018, 2:37 PM   #71
.....no one else is making Rotors no more for the tv antenna so either you point the ANTENNA just Right or buy 2of the same antennas installed in a v pattern will work well.....no b.s. antenna installers use it for a lot of applications becuse iT's better Then using a rotor and one less thing to worry about its the way too GO.....you use 2HDB91 2ft apart in a v pattern you will receive BROADCASTING station that you are looking too get in the different direction of the tower's good luck..... ask rabbit about this set up I guarantee it will work well for you and you will be happy than a pig in sht.lol
Interesting idea.....I don't know how to do the v pattern. Are the antennas separate and you use a switch to change from one to the other, or are they combined together? If they are combined, what do you use to combine them?
