Old 31-Jul-2018, 1:42 PM   #3
JoeAZ
Before you buy anything you may want to try: Temporarily
separating the two antennas by eliminating the combiner/splitter.
You will need to get on the roof, run a separate line from each
antenna to your tv. If your reception improves, you know that
the combiner is causing the phase cancellation that ADTech
is referring to. Hope this helps.
