I can see why you want an attic antenna at the Mountain Bridge Community. Yet, with stucco walls and concrete roof tiles, an attic antenna is iffy.
If an attic antenna doesn’t work, I’d install a J pole on the rear gable end a few ft left or right from the ridge. I’d mount an ANT 751 1 ft higher than the ridge. This combination would be nearly invisible from the street and perfect for reception.
